Results 1 to 11 of 11
    Default brick and block questions
    New construction townhomes.
    All of them have the exposed bricks above the entrance, and the honey-comb item between the blocks.
    I've never seen either before.
    Default Re: brick and block questions
    Weep holes and screens?
    James Duffin's Avatar
    James Duffin Guest
    Is that the brick veneer sitting on the lentil?
    Yes, as far as I can tell.
    Lintel, by the way, not lentil. Although, I do like lentils!
    James Duffin Guest
    Thanks....my mother taurght englys for 35 years but you put her to shaame with your knowledge. I had another bit of pertinent info but I forgot what it was...I know it was good though!
    Plastic screen to prevent insect entry, very common on weep holes.
    Thanks! Not common around these parts, obviously.
    As others have said, those are head joint inserts which serve as weep holes, however, the problem I see is improperly laid bricks, improperly corbeled bricks (which leads to an improperly supported wall), and not through the wall flashing (which is required to be extended all the way out to the edge of the lintel).
    That's what I see at first glance, may be more with a better looksee .
    Is that veneer bowing or is that just a photo affect/distortion?
    Check out the attached, looks exactly like what you have pictured regarding the rectangular weep with stainless screen, presuming there's still some cotton sash cord set up - too new to have rotted away yet or been picked out by a bird or rodent for nesting material, right?
    here is a direct link to the web for what i've attached (for those who prefer that method of access): http://www.masonpro.com/productdatas...weeps_wick.pdf
    This the one I was thinking of:
    Weeps and Vents | WIRE-BOND
    Jul 2007
    Chicago
    Methinks she's gonna leak after a few good directional rains.
