Thread: Condensate
06-07-2011, 04:05 PM #1
Condensate
Why would there be a hole in the plug in secondary condensate. If main becomes plugged water will drain onto furnace components? I was thinking something to do with pressure?
06-07-2011, 04:20 PM #2
Re: Condensate
Secondary drains should be piped to exposed safe locations, not plugged. Discharge from piping will indicate a problem with the primary drain. If primary line plug's up and secondary line is plugged the internal drain pan will overflow and leak
06-07-2011, 05:14 PM #3
Re: Condensate
Tom, That is for a installation over finished living space. This is in a basement, I should have stated that.
06-07-2011, 05:28 PM #4
06-07-2011, 05:43 PM #5
Re: Condensate
Dumping any moisture into the crawlspace or areas of accumulation is always a bad idea, moisture attracts all kinds of insects, can contribute to differential settling and facilitate the growth of a variety of molds that can promote unhealthy conditions. Interlocked detector / cutout switch should be used if impracticable to drain the secondary line. The switch cuts off the power supply and stops the system operation as soon as the water starts accumulating. [IRC]
06-07-2011, 07:45 PM #6
Re: Condensate
Needs to be plugged!
Dan Hagman ACI
ProSite Home Inspections
Des Moines, Iowa
