Results 1 to 19 of 19
Thread: QUIZ
    Guy D Brand Sr's Avatar
    Guy D Brand Sr Guest
    Default QUIZ
    I know you guys have seen a lot out there, but I think this one is up there!
    Quiz questions are:
    1. Was a permit pulled?
    2. Was it possible to move the ceiling box over 8"?
    Just had to show this one off !!!!
    FYI: This is two car attached garage (conversion in progress) with FROG & full bathroom over.
    Sep 2009
    Rolla, MO
    Default Re: QUIZ
    If a house falls in on an idiot and no one is around to hear it does it make a sound?
    Randy Mayo, P.E.
    http://www.rlmengineers.com
    Default Re: QUIZ
    Quote Originally Posted by Randy Mayo View Post
    Good question!!!!
    Default Re: QUIZ
    Quote Originally Posted by Guy D Brand Sr View Post
    with FROG ...
    I know I've seen that used here before, and that I've asked this question before, but I don't see it enough to remember what it means, soooo ... what is a "FROG"?
    Family Room Over Garage is all I can think of, but I don't understand what calling that a FROG would be different from BROG for a BedRoom Over Garage ... and you never see that used???? Or a GROG for GuestRoom Over Garage.
    Default Re: QUIZ
    finished room over garage
    Default Re: QUIZ
    Okay, thank you, but ... I'll probably forget it again for the next time.
    At least you can see the original beam was covered with the required 1/2" gypsum board ... yeah, that's it, they were exposing it for you so you could see it and not wonder if that was done.
    Default Re: QUIZ
    You and me too!
    Default Re: QUIZ
    Now, a French Canadian is sometimes affectionately known or called a frog but I never got that one either. Not sure if I ever asked but tried to piece it together on many occasions. For all I know its a bad word.
    Default Re: QUIZ
    "I know you guys have seen a lot out there, but I think this one is up there!"
    Yeah, what a dumba$$. All he had to do was cut the ends off of a couple of blades.
    Ted, besides 'frog', wasn't 'French' also a bad word for a while? Aren't y'all still eating 'freedom' fries down your way?
    Default Re: QUIZ
    I
    I am not a subscriber to all that freedom fry stuff. Nor was I subscriber to a man telling me in a conversation that because I was white I owed him and his family something for some reason or other.
    I lived in mass for 36 years and I remember back then that it was canucks that were the nice guys and frogs that you had to watch out for but never subscribed to any of that either. Every race had their nick names like mine, I had several being Cherokee, Italian and Irish. I heard them all.
    Dec 2009
    Florida
    Default Re: QUIZ
    [quote=Jerry Peck;174311]I know I've seen that used here before, and that I've asked this question before, but I don't see it enough to remember what it means, soooo ... what is a "FROG"?
    Well, in communications lingo, to "Frog" a circuit means that you have switched some part of the circuit with the same part in another circuit to determine what part is failing. Done when failure continues but trouble can't be tested. Just another bit of useless trivia.
    Stephen G's Avatar
    Stephen G Guest
    Default Re: QUIZ
    More use of the 'Frog
    I was in the army a bunch of years.
    When wearing a web belt and yolk. The frog is secured, so it is located, centered over the left buttock (for fixing bayonets). The scabbard and bayonet can then be attached to it. Frog.
    Steve
    Default Re: QUIZ
    No explaination needed.
    South-West Michigan
    Post Re: QUIZ
    Well, speaking of non-permitted alterations . . .
    Randall Aldering GHI BAOM MSM
    Housesmithe Inspection
    www.housesmithe.com
    Nov 2009
    winslow, maine
    Default Re: QUIZ
    It could be termed an insult, though it has been used as a mere nickname too. There is no clear answer to how the name came about, but it is thought that the French term for English,’Rosbif’ and the English term for French as ‘frogs’ came out mutually..
    The English were called rosbif for preferring Roasted Beef while the French were called frogs simply because they had frog legs for meal!
    Default Re: QUIZ
    Quote Originally Posted by Marcel Cyr View Post
    I have heard that before. Thanks for refreshing the memory. I know a co-workers name years ago was Romeo. He was a Frenchman. His box name was the frog. Everyone played with his name all the time do he just said, call me the frog.
    Daniel Mosier's Avatar
    Daniel Mosier Guest
    Lightbulb Re: QUIZ
    Good question!!!!
    Yes it does make a sound. Sound is defined as the PRODUCTION of waves, not the reception.
    Robert Metheney's Avatar
    Robert Metheney Guest
    Default Re: QUIZ
    I know its been hot, but.....
    Default Re: QUIZ
    I'm a wooden-booter. Anyway, since this thread is a quiz, therefore educational, here's a few definitions for 'frog'.
    frog (frôg, frg)n.
    1. Any of numerous tailless (hey, that is offensive, n'est pas, Marcel? ), aquatic, semiaquatic, or terrestrial amphibians of the order Anura and especially of the family Ranidae, characteristically having a smooth moist skin, webbed feet, and long hind legs adapted for leaping.
    2. A wedge-shaped, horny prominence in the sole of a horse's hoof.
    3. A loop fastened to a belt to hold a tool or weapon.
    4. An ornamental looped braid or cord with a button or knot for fastening the front of a garment.
    5. A device on intersecting railroad tracks that permits wheels to cross the junction.
    6. A spiked or perforated device used to support stems in a flower arrangement.
    7. The nut of a violin bow.
    8. Informal Hoarseness or phlegm in the throat.
    9. Offensive Slang Used as a disparaging term for a French person.
    Adding this one 10. A finished room over a garage
    11. Verb - to "frog" a circuit means that you have switched some part of the circuit with the same part in another circuit to determine what part is failing.
