    Feb 2011
    Ohio
    Default Compression Copper Gas fittings / pipes
    I have never seen this.
    The entire house from the exterior gas meter, into the home has these
    compression fittings with copper gas supply pipes. All were labeled "Natural Gas" on the interior runs. This appears to be standard copper piping.
    It some cases, the copper pipe connects to some small pieces of standard gas pipe fittings, just before going to the appliances.
    Is this allowed? Code? The house is 4 years old, located in Ohio.
    Pics attached.
    Any comments, Code referances?
    Thanks / Rich
    Default Re: Compression Copper Gas fittings / pipes
    They're Pro-Press fittings. They are marked for gas, and use an o-ring and crimping tool.
    Utah
    This is actually a very decent product and even though a bit spendy produces a very clean final installation. Some installers love it for the labor savings.
    Zibby Bujno's Avatar
    Zibby Bujno Guest
    picture #3. If its drip leg then it should be 3" min.
    As far as Propress copper for natural gas line, hummm...
    Binford Tools's Avatar
    Binford Tools Guest
    with the price of copper, or the issue with thief, I would think its a dying form of piping. I see a lot of the yellow flex stuff now.
