Thread: Cedar or not?
    mathew stouffer's Avatar
    mathew stouffer Guest
    Default Cedar or not?
    Base of the column is in contact wit concrete. Could not tell if this was cedar or fur.
    Default Re: Cedar or not?
    It's Pine. When not unfinished like that you can get down and smell it or touch for the softness of cedar.
    I tried that. Poked at it, smelled it, then saw the sap. Just wanted to make sure
    Tiny bit of sap on this one.
    How many inches is it above grade?
    If you are asking for the reason I think you are, knowing the answer is only one component you need to consider and ask, the other is: "Is it heartwood?", if not, then it still needs to be protected from the concrete.
    6 to 8
    Southwest US
    And old growth of which there isn't any more of. I've seen dryrot and termites in redwood and cedar both. Doesn't really matter what species of wood it is. On the other hand, if that's a dry crawl space and there isn't any deterioration I wouldn't call that out as an issue.
    Could be half a dozen different species.
    New York
    The best way to tell if it's fur is by looking around. There is usually an expensive woman nearby.
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Wrong crawlspace Steven
