		Thread: NM for slide-in dual fuel range
	11-03-2011, 06:37 AM #1
		The dual fuel range has gas burners on top, but the oven is electric.
Can I run a continuous 8/3 nm cable from my panelboard, securely fasten it along floor joists, and then run it up a drilled hole located in the floor at the very rear of the range floor space just infront of the back sheetrock wall.?
It would come through the hole, coil about 3 feet behind the stove and enter the stoves junction box with an mn connector?
Slide in stoves don't get pushed back all the way in. There is about a 2" space from the sheetrock wall to the back of the stove.
My contention, back there , it would be physically protected.
The CB would be used as a disconnecting means and if needed a CB lockout tagout device could be used to safely disconnect the power if the stove needs to be serviced.
Tring to get away from the large bulky plug & receptacle.
	11-03-2011, 08:28 AM #2
 Re: NM for slide-in dual fuel range
		Do the installation instructions indicate that the stove should be plugged into a stove receptacle rather hard wired?
Two inches may not be deep enough to accommodate the plug and receptacle as you indicate.
	11-03-2011, 11:43 AM #3
		You can wire either way.
My concern was it proper to come up through floor without a box and coil about 3 feet of the nm cable and connect directly into the ranges electriacal j-box w/nm connector.
Or do I have to come into a box on the floor, lets say, strip the outer sheath and come out of the box with the wires inside a length of greenfield.
Or (sorry) Is a plug & receptacle required?
	11-03-2011, 12:35 PM #4
		As I already pointed out refer to the manufactures installation instructions.
	11-03-2011, 01:24 PM #5
		In accordance with its listing and approvals and the region's codes, any more restrictive provision must be followed.
Both the connection/disconnection and the gas appliance connector and valve, accessible and able to be inspected/accessed.
What you "can" do we aren't able to assess. What you "may do" is covered by both the electrical (appliance) areas and the gas codes. A "slide in" range is not a "built in" range nor a "wall oven" nor a drop in "cook top".
Don't forget your anti-tip provisions and your clearances open air and combustible surfaces.
	11-03-2011, 03:36 PM #6
		A "slide in" range indicates to me that it is not a "free standing" range as I suspect you are thinking "slide in" is referring to.
The "slide in" ranges I have seen rest on the countertop and "slide into" a notched in the countertop and the cabinets, typically there is a cabinet drawer below the "slide in" range. Once the "slide in" range is slid in, it is screwed into place and becomes a "built in" range the same as a drop in cook top and a wall oven becomes.
	11-03-2011, 03:41 PM #7
		.typically there is a cabinet drawer below the "slide in" range.
That would be a "drop in " range, looks a lot like a slide in. The "slide in" sits on the floor or on it's own support. A "drop in" needs a cabinet, drawer, or whatever, for a base.
Dom.
	11-03-2011, 09:56 PM #8
	11-04-2011, 07:28 AM #9
		there is typically a spot at the base of slide in ranges that allow for the gas and electric supplies so even though the range is 2-3" away from the wall, there is a good 6-8" of space where cord and plug and gas connections can tuck under.
