		Thread: Superhydrophobic coatings
	11-16-2011, 06:16 AM #1 Superhydrophobic coatings Superhydrophobic coatingsInteresting product.
 Superhydrophobic Coatings | Corrosion Control & Waterproof Coatings | NeverWet
 Video
 Overview
	11-16-2011, 06:27 AM #2 Re: Superhydrophobic coatings Re: Superhydrophobic coatingsKinda like RainX for your walls.
 It could be useful on my rental properties, but how would I repaint?
	11-16-2011, 06:30 AM #3 Re: Superhydrophobic coatings Re: Superhydrophobic coatingsCould make inspectors impervious to law suits.  Spray it on before any inspection. Spray it on before any inspection.
	11-16-2011, 06:31 AM #4 Re: Superhydrophobic coatings Re: Superhydrophobic coatingsI have used hydophobic polyurethanes when waterproofing foundation cracks, but would be careful where I recommend them as far as moisture/air or vapor barriers.
 Remember; there is a difference.
	11-16-2011, 06:32 AM #5
	11-16-2011, 07:55 AM #6 Re: Superhydrophobic coatings Re: Superhydrophobic coatingsBy the way, just because water beads on a surface does not mean that service is impervious to moisture penetration.
 For example at my water intrusion inspections I often find walls that have been treated with waterproofing materials (usually a paint) and on which water beads readily, but when tested with a RILEM tube are highly absorptive.
 And this isn't just a theoretical distinction, I'm usually looking at the wall because water intrusion through the wall's surface is causing serious problems at the interior of the building.
	11-16-2011, 01:44 PM #7 Re: Superhydrophobic coatings Re: Superhydrophobic coatingsThis looks like a very cool product. I was impressed they coated an i-phone and dropped it in a bucket of water for 30 minutes.
 The bad part is, its not available for sale to the public at this time.
	11-16-2011, 06:41 PM #8 Re: Superhydrophobic coatings Re: Superhydrophobic coatingsBesides Decker that makes you the second guy I know using one.
 Guess I better put my order in.
 Mike ,what areas besides Split Block wall coverings are where you are finding a good use for the tube?
 Interesting statement because I always figured looking at the wall in general was a good indicator (dark moisture stains after a rain)
 The only issue I have with the Matts testing is it is only sampling a small micro portion of a individual block.
  Reply With Quote Originally Posted by Raymond Wand
