Thread: Superhydrophobic coatings
11-16-2011, 06:16 AM #1
Interesting product.
Superhydrophobic Coatings | Corrosion Control & Waterproof Coatings | NeverWet
Video
Overview
11-16-2011, 06:27 AM #2
Re: Superhydrophobic coatings
Kinda like RainX for your walls.
It could be useful on my rental properties, but how would I repaint?
11-16-2011, 06:30 AM #3
Could make inspectors impervious to law suits.
Spray it on before any inspection.
11-16-2011, 06:31 AM #4
I have used hydophobic polyurethanes when waterproofing foundation cracks, but would be careful where I recommend them as far as moisture/air or vapor barriers.
Remember; there is a difference.
11-16-2011, 06:32 AM #5
11-16-2011, 07:55 AM #6
By the way, just because water beads on a surface does not mean that service is impervious to moisture penetration.
For example at my water intrusion inspections I often find walls that have been treated with waterproofing materials (usually a paint) and on which water beads readily, but when tested with a RILEM tube are highly absorptive.
And this isn't just a theoretical distinction, I'm usually looking at the wall because water intrusion through the wall's surface is causing serious problems at the interior of the building.
11-16-2011, 01:44 PM #7
This looks like a very cool product. I was impressed they coated an i-phone and dropped it in a bucket of water for 30 minutes.
The bad part is, its not available for sale to the public at this time.
11-16-2011, 06:41 PM #8
Besides Decker that makes you the second guy I know using one.
Guess I better put my order in.
Mike ,what areas besides Split Block wall coverings are where you are finding a good use for the tube?
Interesting statement because I always figured looking at the wall in general was a good indicator (dark moisture stains after a rain)
The only issue I have with the Matts testing is it is only sampling a small micro portion of a individual block.
