Results 1 to 12 of 12
Thread: Heat shield
12-08-2011, 08:15 AM #1
Heat shield
Is this intended to be a permanent part of a heat shield or packing material. This is an American Standard 90 percent gas furnace.
12-08-2011, 08:23 AM #2
Re: Heat shield
Aftermarket vibration dampener ?????
Had a rattle/hum that bothered them.
12-08-2011, 08:31 AM #3
Re: Heat shield
Appears that the shipping/packaging material was never removed.
12-09-2011, 06:10 AM #4
Re: Heat shield
It's a noxious smoke generation system, for random testing of the smoke alarms in the home.
12-10-2011, 07:54 AM #5
Re: Heat shield
They would take it out but it burned their fingers.
12-10-2011, 09:36 PM #6
Re: Heat shield
Thought it might be a good place to thaw out some steaks.
- James Burgh, 1754.
12-11-2011, 07:15 AM #7
12-12-2011, 07:05 AM #8
12-12-2011, 07:33 AM #9
Re: Heat shield
Had a similar situation on a 80 furnace in a mobile home. They used egg crate material. Only found 1 scorch mark on the three areas they stuffed it.
12-12-2011, 09:44 AM #10
Re: Heat shield
I cant tell by the photo if it is a paper packing (egg crate) type material or if it might be a material that is similar to rock-wool insulation, like some of the covers being used over non-IC rated recessed lights. I'm just curious enough that I would break off a piece and and try to burn it. I would agree that it is probably been put there as a vibration dampener.
Apollo Home Inspection
St. George UT
12-12-2011, 09:45 AM #11
Re: Heat shield
haha, some great replies. All related to The Darwin School of Fix It.
12-12-2011, 06:00 PM #12
Re: Heat shield
I would say it was some packing material. Some older furnaces would have similar heat shields, but with this one being a 90% you just wouldn't have that much heat to worry about.
