Results 1 to 14 of 14
12-15-2011, 01:39 PM #1
Foundation wall changing colors...
Any idea why the brick and concrete block are turning the orange red color about half way up?
See pics.
12-15-2011, 01:46 PM #2
12-15-2011, 01:46 PM #3
12-15-2011, 01:53 PM #4
Re: Foundation wall changing colors...
Ok, so this could be pressure washed off no problem?
12-15-2011, 01:55 PM #5
12-15-2011, 02:07 PM #6
No, but I did try to wash a pair of sneakers after a charity mud run once. After the third unsuccessful wash they ended up in the trash.
12-15-2011, 02:14 PM #7
Maybe from an irrigation system?
12-15-2011, 02:39 PM #8
Most likely it has stained the brick to the point that it can not be cleaned. Stay away from pressure washing! More folks screw up their homes by pressure washing them; it can and will force water into areas that it just does not need to go.
An acid wash and a stiff brush might get rid of some of it.
12-15-2011, 04:12 PM #9
That is my thought too.
That pattern is like those caused by sprinklers. Anyone in areas with high iron content in the well water for sprinklers will recognize that.
The water for our sprinklers here in Ormond Beach is not that bad, just eventually leaves a slight discolortion.
The water for our sprinklers in South Florida had a chemical tank which canceled out most (but not all) of the rusting color from the water.
12-15-2011, 04:40 PM #10
I had not thought about rust stains from a sprinkler, but being from Georgia, my money is still on clay.
12-15-2011, 07:03 PM #11
Wet Dog rubbing against them.
My Grandpas dog rubbing his but on a fence - YouTube
12-17-2011, 10:22 AM #12
Confidant at this point it is Georgia red clay. The yard has plenty off it. I know this because I'm currently digging a french/curtain gravity drain underneath the perimeter of the below grade crawl space. Had some standing water on the low side perimeter when I bought it.
Also, the back yard did have a big wet chocolate lab living in it from the previous home owners...
Not underground sprinklers are installed. Ground stays fairly saturated in the back yard.
12-17-2011, 12:35 PM #13
That dog mnay have been doing more than rubbing on them?
12-17-2011, 01:04 PM #14
