Thread: Exposed flue
01-20-2012, 09:41 PM #1
Exposed flue
Do you think that exposed flue liners will affect drafting due to the potential temperature difference from the liners surrounded by brick and these which are exposed? I mean its only two liners....
Similar Threads:Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
01-20-2012, 10:26 PM #2
Re: Exposed flue
01-20-2012, 10:35 PM #3
Re: Exposed flue
01-21-2012, 04:18 AM #4
Re: Exposed flue
that was added.
now it needs a full level 2 inspection
good idea smart guy
was there an addition, Dormer, within 10 feet, up there where the height adjustment was required?
01-21-2012, 07:19 AM #5
Re: Exposed flue
When I see something like that I wonder why it was done - mostly likely because something was not performing correctly to begin with.
01-21-2012, 08:32 AM #6
Re: Exposed flue
01-21-2012, 09:26 AM #7
Re: Exposed flue
Here's the only image I got from a distance.
01-21-2012, 09:29 AM #8
Re: Exposed flue
Chimney flue liner extensions OK, color not !
01-21-2012, 10:40 AM #9
Re: Exposed flue
JC, I think you mean those don't look like real flue tiles? and you might be right.
I agree it needs to be checked out, and repaired or upgraded. Most likely it was done to cure a downdraft issue from wind coming over the roof.
They will get some cooling on those top two tiles, so there will be creosote build up there. If they only burn store-bought Presto logs or bone dry wood, that won't be much of an issue.
A house up the road from me has that same chimney design. It has survived about 4 years now. It's our local seismic event gauge.
01-21-2012, 06:24 PM #10
Re: Exposed flue
last time I checked a 'chimney' was comprised of a min. 4" wythe wall surrounding a flue liner. If you need to extend the flue gas outlet, you need to extend the chimney.
