Thread: Chemical reaction?
02-10-2012, 04:01 PM #1
Chemical reaction?
Home is only 5 yrs old and neither pipe has been replaced. Why would one be so tarnished and the other not at all?
Similar Threads:If it weren't for lawyers, we would never need them.
02-10-2012, 04:15 PM #2
Re: Chemical reaction?
Poorly made flex connector, or no dielectric union/coupler on that piece.
02-10-2012, 07:50 PM #3
There was a DE on that pipe. May not be working, but it was there. Still wondering what else it could be.
02-10-2012, 09:57 PM #4
Water heater is back-drafting, and sulfur is corroding the copper?
02-11-2012, 06:41 AM #5
The Guy who left his Foot Print on the Wall did it.
02-11-2012, 10:39 PM #6
I'm with Dom. It definitely looks like sulfur corrosion. I would say Chinese drywall but it would likely be on both lines. Check for back drafting in the direction of the line.
02-16-2012, 09:55 AM #7
Flue gasses condensing on cold water line?
02-17-2012, 07:48 AM #8
02-17-2012, 11:26 AM #9
Seems like an extreme example, but heat can speed up corrosion rates. Is the bad one the hot water?
- James Burgh, 1754.
02-17-2012, 11:49 AM #10
Heat can speed up corrosion, but the type of corrosion present suggests something else. That's why I suspect it's the cold water pipe - if sulfur dioxide condenses on the cold water line with water it it will form sulfurous acid and sulfuric acid which will corrode copper as in the image.
