Results 1 to 11 of 11
Thread: Who needs combustion air?
01-24-2012, 02:26 PM #1
As I keep telling clients, I see something new at every inspection.
Similar Threads:"There is no exception to the rule that every rule has an exception." -James Thurber, writer and cartoonist (1894-1961)
01-24-2012, 03:42 PM #2
Re: Who needs combustion air?
That's a great filter did you tell them to change it often. It's funny when installing these systems they can get away with such issues. Look at this furnace I just saw.
01-25-2012, 10:29 AM #3
01-25-2012, 11:31 AM #4
Also, is it ok the vent to masonry chimney? A wood burning or gas burning fireplace?
01-25-2012, 12:42 PM #5
Fine to vent through the chimney, but the issue is improper material used to vent from the furnace. It was a very shady job on the furnace with the supply plenum cut off and funky vents all over the basement for heat. The chimney was also a good clue for an oil tank.
01-25-2012, 06:50 PM #6
Was the vent just some Class 0 flexible duct or was it a Metal-Fab B-vent?
http://www.mtlfab.com/media/L1940.pdf
Corey
01-25-2012, 10:48 PM #7
01-27-2012, 12:07 PM #8
It is not okay to vent an 80% furnace to a masonry chimney unless it has a metal liner according to most manufacturers because of the cooling and condensation issues
02-14-2012, 06:35 AM #9
The primary reason for this is that when the chimneys were designed, the gas appliances connected had standing pilots which constantly provided minimal heat source to the chimney keeping it warm allowing good draft. When you remove a standing pilot device and install an intermittent pilot device, the chimney cools during the off cycle. When the device then starts its cycle, the combustion gasses cool in the chimney preventing proper draft.
02-14-2012, 08:40 AM #10
Dang that's down right scary. Not enough air would mean incomplete burn which could crate very high CO.
Here they require a 90 ell on the intake to prevent something from accidentally falling and restricting the intake. But in this case the HO might have still stuff a rag in it
02-14-2012, 09:50 AM #11
