Results 1 to 12 of 12
Thread: Drain configuration question
09-25-2007, 03:42 PM #1
Similar Threads:Last edited by Jeff Eastman; 12-03-2007 at 09:58 AM.
09-25-2007, 04:47 PM #2
Re: Drain configuration question
Nope. What's in your photo is one correct way.
But ... where does that other drain line go to which is going off to the left of the 'tee' down from the sink?
First, though, that sink will have poor draining capability with it draining down to a 'tee' like that - the waste drains down and hits the bottom of the 'tee', then needs to figure out which way is 'down' from there. The correct way would be for it to drain down into the top of the 'tee' (like the disposer is connected into the other 'tee'), with the side of the 'tee' going out to whatever is to the left.
09-25-2007, 04:54 PM #3
Jerry, read the original post again, from your comment, I don't think you got the layout that I had pictured in my mind. I think the far left is from a clothes washer in another room, the middle is the left sink and the right is the disposer... I would think that the setup would be wrong, but I can't quote the reasons right now, got to get back to my report.
Jim
09-25-2007, 04:57 PM #4
09-25-2007, 05:10 PM #5
For a "clothes" washer (which was not stated, so I skipped over 'what type of' "washer") - that's all wrong.
A "clothes washer" requires at least a 2" drain, not a 1-1/2" drain like at that sink.
Plus, that is not allowed to dump into the kitchen sink (refer to other long drawn out discussions regarding what is allowed to connect where when used for "domestic" or culinary purposes).
That clothes washer probably backs suds and maybe even water up and out, and that pump driven discharge could separate those slip joints - they are not made for that force or volume of water.
09-25-2007, 05:14 PM #6
Well put, Jerry.
Now I have GOT to get back to my report.
This board is addictive!
09-26-2007, 08:44 AM #7
jeff,
in picture #2 the drain slope should be 2% minimum and that corrugated drain line is a code violation. code reads"smooth interior waterway" for drain piping. this stuff is a hacks best friend
09-26-2007, 12:00 PM #8
photo #2?
Oops ...
I guess I got to looking at photo #1 and skipped photo #2 -
Yeppers, those flexible drain lines are allowed to be manufactured, are allowed to be sold, are allowed to be bought, BUT they are not allowed to be installed.
Daddy, what's that funny looking corrugated thingy hanging up on the wall?
Well, my son, that is one of the biggest catches Daddy ever made - I went to the store and bought one, knowing I was not allowed to install it, so there it is - framed and on display.
09-26-2007, 12:58 PM #9
Here's a photo of one of JP's thingys. He managed to get two defects for the price of one. Way to go Jerry!
09-26-2007, 01:04 PM #10
Why, that's a lower radiator hose for a 1966 Plymouth Valiant!
09-26-2007, 01:29 PM #11
09-26-2007, 01:48 PM #12
Slant 6
