Results 1 to 13 of 13
04-21-2012, 10:50 AM #1
What am I looking at? (Electrical component identification question)
This device (picture 1) was located in a box to the side of a load-side panel in a basement - the box in which it was mounted is to the left of the load-side panel in pictures 2 & 3.
(The odd "stain" at the left hand side of the second and third pictures is an artifact introduced when I pulled up a shadowed area in Photoshop.)
Identification?
Function?
Thanks in advance
04-21-2012, 11:04 AM #2
Re: What am I looking at? (Electrical component identification question)
It looks like a 4-pole contactor. Nothing more than a fancy electrically operated 4-pole switch.
04-21-2012, 11:12 AM #3
It's a 30 or 40 amp rated, ( too much strobe light ), relay or contactor, ( I've forgotten what discriminates one from the other ). Regardless an electic coil operated control device. Often used to start & stop a motor, but it can control any electrical device within it's maximum allowable amperage limits, ( outside lights, a gate motor, a central vac system, a heater, or ? ). There will be some control wires involved that go to some push buttons, a switch, a photo-cell or some other remote control device, ( in this case obviously not wireless ).
04-21-2012, 11:52 AM #4
There *is* a central vac installed at this property...
04-21-2012, 02:21 PM #5
This data sheet from Potter & Brumfield decodes the specs (P30P49...)
http://documents.tycoelectronics.com...=DS&DocLang=EN
04-21-2012, 07:06 PM #6
It is a old (Siemens* owned Potter & Brumfield for years) definite purpose DP contactor, if you look at the label notice the RU & the lack of a UL symbol it's a UL recognized component of UL listed equipment, it is not UL listed.
* Not sure if they still still do.
04-21-2012, 07:57 PM #7
Its marked AMF that's the pre-Siemens owner of P & B, which coincides with the '83 mfg date stamp of the recognized componant.
Hey M.T., did the property have multiple sump pumps? an ejector for the basement? a water treatment system? private water supply/Pressure tank or If public supply, only available within the last two decades? If no, then I'd best-guess can't trace a wire via pic - go with the central vac.
Mag contactor, as you indicated in your title, yep, its just a recognized componant (likely after-warranty or after-original application replacement sourced gray market part).
Edited to add:
P.S. I just slapped myself in the head when I (duh moment
) realized it was a 120 Vac coil. Ix-nay on the well pump/pressure tank question!
Last edited by H.G. Watson, Sr.; 04-21-2012 at 10:09 PM. Reason: added post script after head self-slapping moment.
04-22-2012, 10:39 AM #8
AMF? It must be for their personal in-house bowling alley
04-22-2012, 04:01 PM #9
Seriously AMF (1970-ish f/k/a American Machine and Foundry since 1900-ish) owned Potter & Brumfield until the hostle Jacobs/Minstar Inc. takeover in 1985 upon which AMF was busted up and assets immediately sold off. P&B was sold to Siemens and the "Bowling" Division was sold to a Virginia group.
AMF was into just about everything - from nuclear reactors to Harley Davidson, P & B, sports equipment, bicycles, bowling (1950s) & billards, and much more.
04-23-2012, 07:56 AM #10
Best yet, it's made in the U.S.A.
04-23-2012, 08:49 AM #11
04-23-2012, 03:30 PM #12
One good way to screw up a Harley.
04-23-2012, 05:14 PM #13
