    WESTMINSTER CO
    Default copper section betweem black iron
    hey all
    is this proper and to code
    thanks
    cvf
    Default Re: copper section betweem black iron
    CVF,
    In my area, copper is not acceptable for use with natural gas.
    Is that really copper? I don't recall ever having seen threaded copper. It doesn't look like brass (too copper-y colored).
    WESTMINSTER CO
    gunnar
    don't know what it is but looks like copper--guess i should have looked closer--but furnace was 1983 rheem--so stated over life expectancy--have hvac guy evaluate
    thanks
    cvf
    Cool Re: copper section betweem black iron
    I think its just red brass that has aged a bit. Brass is fine--that's what the shutoffs are made of. Speaking of shutoffs, I hope you called for the replacement of that clunker serving the WH.
    What does that ss flex connector serve? I don't see a sediment trap before it.
    Also, inadequate service access in front of the WH
    My guess it is brass too.
    In my area, copper is allowed to be used for natural gas. One of the gas providers also says that sediment traps are not needed.
    The gas control valve manufacturers and OEM equipment/appliance manufacturers often say differently (Standards for safety,fuel gas codes) for automatically operated appliances (boilers, furnaces, water heaters, etc.).
    Are you completely sure they aren't referring to "drip legs or drip traps" in such a statement ('dry' gas); or they aren't referencing the non-requirement for a sed trap for most controlled/attended operation appliances (cook tops, ranges, ovens, log sets, log lighters, fireplaces, stoves, clothes dryers, grills, decorative appliances, illumination devices, etc.).
    Didn't he tell us the 'red brass', as you identified ir (to valve to SS appliance connector) was supplying a nearly 20 y.o. Rheem furnace in post #3?
    Dennis Krouse's Avatar
    Dennis Krouse Guest
    I also think its a good call on the brass nipple. Its funny how the other things just start getting told and noticed. Gotta luv it.
