Thread: What are these?
04-27-2012, 03:38 PM #1
04-27-2012, 04:13 PM #2
Re: What are these?
Look like CTs for energy measurement systems or metering.
04-27-2012, 05:19 PM #3
Re: What are these?
For those who don't know, CT stands for 'current transformer'.
When current flows through a conductor a magnetic field is created around the conductor. When that current is ac current, the magnetic field expands and contracts with the ac voltage sine wave.
That expanding and collapsing electromagnetic field generated current flow through a conductor placed within that magnetic field. The CTs are simply coils which generate ac voltage and current at their leads when ac current flows through the conductor run through the current transformer. The CTs are calibrated (the are manufactured to create a given current and voltage based on the magnetic field, which is directly related to the current in the conductor.
Thus, for a given current through the conductor, a known current and voltage will be generated by the CT, and that known current and voltage can be used for metering, for monitoring the current flow and overcurrent devices, and for other things.
04-27-2012, 06:11 PM #4
Re: What are these?
Thanks......So who or what could be using these to measure the current?
04-27-2012, 06:17 PM #5
Re: What are these?
The power company may have installed a CT meter, it works the same as a regular power meter except that the calibration is different (instead of 200 amps running through the sensor there may only be a few amps, depending on the CTs and the meter calibration.
I have not done much with CT meters, so I am sure there are others here who can expand on what I have posted, and even correct me where I am totally wrong (likely the amount of current from the CT).
04-27-2012, 07:16 PM #6
Re: What are these?
Might be part of a system like this.
TED 5000
Lets users see how much power is being used and where.
04-27-2012, 08:55 PM #7
04-28-2012, 06:10 AM #8
Re: What are these?
Thanks guys......
04-28-2012, 11:53 AM #9
