Results 1 to 20 of 20
05-09-2012, 03:43 PM #1
New House Panel - Potential Issues
I saw this in the service panel of a new construction house this afternoon. The 1st pic shows what appears to be evidence of arcing on the hot bus bar. It looks like somebody hit about 4 stabs at once and created some attention grabbing arcing. Does this pose any issue moving forward like rendering those stabs unacceptable for breaker installations or void any warranty from the panel manufacturer?
The second pic shows how all the breakers in the panel are labeled. For a 200 amp panel in a 2700 square foot house, I expected to see more breakers. Are there any code issues at play here with the way some of these circuits are set up? Some have 3-4 different areas wired to the same circuit.
Similar Threads:Last edited by Nick Ostrowski; 05-09-2012 at 05:30 PM. Reason: correct my terminology
05-09-2012, 04:21 PM #2
Re: New House Panel - Potential Issues
IMO those particular bus stabs have been compromised.
05-09-2012, 04:48 PM #3
05-09-2012, 04:52 PM #4
That's IT???
I don't know how they got away with it, but I will say, the letter of the code allows for quite a large ares on one 15A circuit. You have to remember, in the US residential general lighting and receptacle circuits are covered in the 3va/sq ft load calc. There is NO limit to receptacle on a circuit.
IMO that panel shows the bare minimum for a house that size. I'd guess spec house, all-in-one contractor with little regard for customer satisfaction, or a completely clueless/careless owner who got taken advantage of.
05-10-2012, 03:57 AM #5
I'm wondering now if maybe the builder set the breakers up in this manner to avoid using the stabs that have the arcing damage.
05-10-2012, 09:14 AM #6
05-10-2012, 09:41 AM #7
But is the bottom section of that bus bar suitable for future use? What are the chances any breakers connected to those stabs could have poor contact and arc? I don't know that I would feel comfortable using those stabs in my own house.
05-10-2012, 12:23 PM #8
05-11-2012, 08:00 AM #9
Nick, I'm curious about how you were able to see the panel bus bars exposed like that (pic #1). Did you remove the breakers as part of your routine?
05-11-2012, 08:38 AM #10
05-11-2012, 09:10 AM #11
05-11-2012, 09:57 AM #12
05-12-2012, 10:26 AM #13
This house probably has all gas appliances; stove, dryer, water heater, heat etc... That would explain the minimal amount of big loads in the panel.
As for the stabs being compromised, that goes without saying! However if the spaces aren't needed and not used there is no need to replace the panel at this time.
05-12-2012, 10:41 AM #14
05-12-2012, 10:56 AM #15
05-12-2012, 11:11 AM #16
Yes, you're right! The builder should replace the panel IF this happened during construction. The electrical inspector who signed off on the job should have demanded it be replaced IF it was damaged prior to final. And the current homeowner should pay to have it replaced if he is selling the house!
I understand the dilemma you face, however the panel could last as is for just as long as a new one (it is a new one) if those spaces are not used. I wouldn't replace it if it were in my own house until I needed more space!
05-14-2012, 07:01 AM #17
Totally irrelevant question, but what could have possibly gotten across that many tabs at once?
05-14-2012, 07:21 AM #18
temp power GF cordsets open neutral along with the hot(s) for protection of workers.
05-14-2012, 10:53 AM #19
05-14-2012, 12:59 PM #20
