Results 1 to 13 of 13
Thread: Insulation install oops!
05-11-2012, 06:05 PM #1
Found the majority of the attic with insulation installed vapor barrier side up. First install job for the new guy?
05-11-2012, 06:25 PM #2
Re: Insulation install oops!
www.inspectaz.com
05-11-2012, 11:25 PM #3
Maybe the manufacturer put the vapor barrier on the wrong side...
05-12-2012, 04:30 AM #4
The ceiling framing was installed upside down??
05-12-2012, 09:40 AM #5
I would double check the insulation underneath. If it were there, I would not worry.
05-12-2012, 11:00 AM #6
05-12-2012, 12:15 PM #7
05-12-2012, 03:41 PM #8
Peter,
Am I understanding you correctly in that you are saying that the exposed facing, which says not to leave exposed because it will burn, is *NOT* a problem?
Please tell me I am misunderstanding what you are saying.
05-12-2012, 05:27 PM #9
Yes, Attic could be extreme hot. Burn hazard, this should be corrected.
05-12-2012, 05:28 PM #10
05-12-2012, 06:02 PM #11
no misunderstanding, Jerry.
05-12-2012, 06:34 PM #12
Peter,
Now I am really confused.
a) I understand you to be saying that it is *NOT* a problem.
b) You say "Attic could be extreme hot. Burn hazard, this should be corrected."
c) I ask for clarification whether you are saying it is a problem and I am not misunderstanding you, or, that it is not a problem and I am misunderstanding you.
d) You say I am not misunderstanding you.
e) (this post) I am not misunderstanding you that it is a) above, that it is *NOT* a problem, or, b) above, that "Burn hazard, this should be corrected."
a) and b) above are contradictory.
I will try again, wording it differently:
1) It is *NOT* a problem and does not need to be corrected.
2) It *IS* a problem and does need to be corrected.
Your answer is: _____
05-12-2012, 09:40 PM #13
2), Jerry
