Thread: Hose bibb height
06-18-2012, 10:32 PM #1
Hose bibb height
Is there a minimum height above grade for exterior hose bibbs? I'm thinking of possible siphoning effect.
Thanks.
06-19-2012, 05:49 AM #2
Re: Hose bibb height
NO but it needs a vacuum breaker.
06-19-2012, 03:28 PM #3
YES ... the height required for an air gap because you know that atmospheric vacuum breaker is going to be removed
... and because of the closeness of the hose bibb to the wall the air gap may need to be 3 or 4 times the effective diameter of the outlet instead of just 2 times the effective diameter.
06-21-2012, 03:02 PM #4
06-21-2012, 07:32 PM #5
Thank you All for your responses.
Stan
06-21-2012, 07:38 PM #6
