Results 1 to 11 of 11
Thread: Plummers Putty
    Don Martin's Avatar
    Don Martin Guest
    Default Plummers Putty
    All that work and it still leaks.
    Default Re: Plumbers Putty
    flex drain not approved
    double -I mean triple trap not approved
    GFGI outlet? How is the dishwasher hose attached?
    rip out and redo properly this time without the putty. DIY Network strikes again
    Default Re: Plummers Putty
    Quote Originally Posted by Don Martin View Post
    Well of course it Still Leaks ( used the wrong putty.)
    https://www.buymightyputtynow.com/?rtag=mightyputty&
    What? If it's not leaking, isn't it just fine. Careful how you report this; you might make a realtor mad.
    Dang it! The problem is they should have used duct tape.
    But really, the first tool to come out of my box to fix this would be a big hammer. I would track down the nitwit who did this and hit him with it.
    Seriously, if you think for a minute or two, it's not that hard to put this stuff together right. Especially that cheap plastic crap. The flex pieces made it even more complicated in my opinion.
    ... it's not that hard to put this stuff together right. Especially that cheap plastic crap. The flex pieces made it even more complicated in my opinion.
    There is no way to put the flex pieces together "right".
    Dec 2009
    Florida
    What!!! No Duct Tape!!!!
    Garry Blankenship's Avatar
    Garry Blankenship Guest
    Wow ! If only I could have bought some plumber's putty stock before that project happened.
    Jul 2009
    Lanham, MD
    Seen this many times. Even had one customer use epoxy to stop a leak around a sink basket strainer. Had a terrible time cutting the thing out without damaging the sink. Sheesh! Even seen cases where one has used a flexible radiator hose for a trap!
    Darrel Hood's Avatar
    Darrel Hood Guest
    On one of my recent repair projects, the galvanized water distribution pipes in the ceiling had leaked in dozens of locations because they were used up and rusted out. The self help homeowner had patched almost all of the leaks using two part epoxy. He was really frustrated when I quoted for replacing almost the entire system instead of just a localized replacement of a leaking joint.
    Apr 2008
    McKinney Texas
    that particular brand of disposal is bad about developing cracks in the disposal body. I see leaks from them often.
