Results 1 to 12 of 12
Thread: ??? at water main shut off valve
06-18-2012, 03:38 PM #1
Something else I've never seen before. 1977 split level. Water pressure was 108 PSI. Anyone seen this before. Any help greatly appreciated.
06-18-2012, 04:24 PM #2
Re: ??? at water main shut off valve
I seen over 120
What do you need help with?
06-18-2012, 04:53 PM #3
I had pressure that snapped my pressure gauge - over 180.
06-18-2012, 05:18 PM #4
06-18-2012, 05:22 PM #5
No issue with the pressure. So I assume you are asking about the device. It is a water meter yoke. The meter is missing and being bypassed with a piece of copper. Perhaps the meter has been relocated to another location (at the street) in which case all is OK. Otherwise someone may be stealing water.
06-18-2012, 09:08 PM #6
Yes I was referring to the device. So it is just something to take up the space where a meter once was? Makes sense. I don't recall seeing a manhole in the yard or street. Thanks for the help.
06-20-2012, 05:17 AM #7
Looks like theft of services
Is there a meter somewhere else?
08-04-2012, 05:52 PM #8
Anyone care to explain and develop more info. about this yoke contraption?
I'd never seen one before the pic, not even in the catalogs.
If the water company did it, why would they do it this way?
If a plumber did it, same question. Surely, it's simpler to merely cap off both open ends when isolating, or upstream side valved-off, and the other side capped.
Or, if connecting across the gap then why not a couple of comp.fittings and a length of cu. tube?
The amount of superfluous fittings and the odd lay-out suggest ... what?
08-04-2012, 05:54 PM #9
Oh, forgot to add that the ground wire has slipped away from its clamp.
08-04-2012, 06:06 PM #10
08-04-2012, 08:38 PM #11
08-04-2012, 09:27 PM #12
