Results 1 to 13 of 13
    Sep 2011
    Bolingbrook, IL
    Default All to the Sump pit
    Hello
    The washing machine, basement kitchen sink and wet bar all drain to the sump pit.
    The PVC line on the left is from the sink. The rear line is from wet bar and the black hose is the washing machine hose.
    Any thoughts?
    Default Re: All to the Sump pit
    where does the sump pit drain to?
    that would be the determineing factor as to right or wrong, and while it is a little hillbilly, that pump is not much differenty than a pump up system for a washer or basement sink.
    If it's going into the sewer line or storm drain, it is not allowed around here.
    If it pumps out to it's own drywell, no problem
    I have seen toilets hooked up to sump pits in the past. NICE!!
    That's not hillbilly.
    strictly south of the border
    dadadada en america
    Sep 2011
    Bolingbrook, IL
    This one is connected to the house drain pipe
    Everything pictured & described is completely illegal (yep, as in even potentially criminal), also note tile pit - in french drain/drywell and direct/contamination. Its a CF of public health hazard, compromize, bootleg idiotic work.
    The Illinois Department of Public Heath
    See: Illinois Plumbing Code, you can free in its entirety at the Gen. Assmbly site from Illinois.gov.
    also administrative code.
    Applies
    Everywhere outside Chicago, within Chicago see City Codes.
    Sep 2011
    Bolingbrook, IL
    Thanks H.G.
    You've got me confused Wayne. Since Donald didn't say anything about ground water going into the sump I ASSumed he was referring to a waste water ejector. If it discharged to the sewer or septic system why would that be a problem?
    Let's clarify this - the sump is the pit, or crock.
    I see a connection for a floor drain or possibly weeping tile on the right side of the crock.
    I vote for "all messed up".
    Yep, that too!
    Ha Ha, I saw one with an overflow drain one time. Nice if your pump quits working, not so nice for the canyon area when the poop is draining into it.
    Erik, Local muni's around here will not allow sump water to enter the sewer lines.
    Letting it go to the septic would stress the system and not a good idea.
    I didn't see the weeping drain prior to my first reply that's why i felt it was not a problem as long as not in a city drain or septic
    There is no poop in the pit, only water from washer, sink, and wet bar, not yet anyway
    the bar is open!!
    The problems with putting the machine and sinks going into a sump pit can end up being not a big deal or a very big deal.
    - Sump pits generally aren't vented or have sealed lids
    - Sump pumps are typically less aggressive and lower HP than ejector pumps. The pump could end up failing far sooner.
    - The machine and sinks will send organic material into the pit. They could end up with a real petrie dish in there. With no vent and no sealed lid, basement air quality, bugs and contamination could all end up being issues.
    Sep 2011
    Bolingbrook, IL
    Thanks for the info
