    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    Question Let's see now ???
    Not sure if it was for minimizing vibration from the "pig" or to hold up the plumbing or a combination of both.
    It was all working fine ... bit noisy w/some vibration, but not bad.
    Default Re: Let's see now ???
    mabey his wife's chin brace fell off as she was installing the disposall.
    Michael Larson's Avatar
    Michael Larson Guest
    I'm guessing that the zip tie is holding up the tee fitting against the disposal discharge fitting. DIY fix for sure.
    In fact the jam nut on top of the tee looks like it could be cross threaded preventing proper tightening.
    It looks like the slip nut is cross threaded, if it is, it will not hold the plumbing tight, can also cause leak at slip joint.
    Vibration/noise
    Thin lightweight SS sink
    Improper mounting
    loose mounting bolts, misaligned mounting flange, loose lock nut (ring)
    Internal problems
    Worn bearings, missing, loose or frozen grinder hammers, rust.
    Not sure if it was for ... or to hold up the plumbing ...
    To hold up the plumbing.
    That slip joint slip nut looks like it is barely on the discharge pipe (others have mentioned it being cross threaded, but that's a minor problem ), and, because there is very little pipe into the slip joint, the force of the disposer's discharge likely blow the slip joint off the end of the discharge pipe.
    Should have used a tail piece extension to get a good fit there.
    Cheap stainless steel sinks? If so, any small vibration from stuck debris will be exaggerated as the bottom of those cheap SS sinks allow the disposer to oil can around.
    Richard Rushing's Avatar
    Richard Rushing Guest
    Definately a DIY fix to a leak at the slip nut. I've seen a dozen of'em and they all would leak if the zip tie was not there.
    rr
    Richard Stanley's Avatar
    Richard Stanley Guest
    Thats a much neater job than duct tape!!
    Could have been fixed a bit easier with just sliding a Chevette tire rim directly under that disposer. If a gap was still present, an egg carton would about shim it up perfectly.
