Thread: Polyurethane Foam Roof
10-04-2012, 12:56 PM #1
On a roof that covered with polyurethane foam and elastomeric coating, which product provides the actual water protection, the poly or elastomeric?
10-04-2012, 01:14 PM #2
Re: Polyurethane Foam Roof
10-04-2012, 05:01 PM #3
Jack,
What kind of roof was that applied to?
Chances are: a) it was not allowed to be applied to the roof; b) the foam was improperly applied; c) the top coating was improperly applied; d) the foam was applied too thin; e) the foam was allowed to get burned (from UV) between layers; f) the top coating was not applied in proper thicknesses; g) the top coating does not have the proper number of layers.
What was the foam applied to/on top of?
10-04-2012, 06:55 PM #4
Was asking for general information and future inspections. Usually, I see this on flat roofs with wood or concrete substrate. Not sure how to determine the a) thru g) issues. Occasionally, I will see this on a flat roof with parapet walls. Never seen a foamed roof with proper drainage.
Thanks for the feed back.
Jack
10-05-2012, 09:11 AM #5
I asked because I have seen that foam applied to shingle roofs (over the singles), to metal pan roofs over patios, over built-up roofs (over gravel and over single ply). Seems like I have seen them applied to where they should not have been applied more often than where they were allowed to have been applied when I did home inspections.
As I recall, I have only seen one ... ONE ... installed properly out of all of them that I have seen.
