    Erwin, TN
    Default Main water line next to service panel
    Inspecting a house today built in 1970 and found the water main water line entry is beside the electrical service panel. Is there a violation with this?? Thanks
    Default Re: Main water line next to service panel
    "next to" - okay ... not smart, but 'okay'
    "over" - baaad ... and not smart
    Stephen G's Avatar
    Stephen G Guest
    I have called out two main water shut offs located above over a bit...if the tap ever started to leak, while using it. buzzzzt...in both cases re routing the plumbing was a very simple fix...but my mind still has trouble thinking that they actually installed it that way. The second trade should have said something...the AHJ should have said something....
    in my area there was no building dept till 1972 or so. i have seen that many times and always call out the hazard and an upgrade recommendation.
    i also have found quite a few bathrooms added above with the toilet right above the panel. brings a few desciptive terms to mind
    Jan 2011
    Guelph,Ontario
    If some thing appears to be a hazard,call it out,better to be safe than sorry,of course common sense should prevail.
    Aug 2011
    An example of violating common sense but not code. However, note the galvanized to copper connection.
    Apr 2009
    NY State
    Quote Originally Posted by Stephen G View Post
    Please explain what you mean by "buzzzzt".
    Are you suggesting if the panel gets dripped on it will buzz?
