		Thread: Under stair protection R311.2.2?
	11-07-2012, 07:45 AM #1
		Anyone know what happened to this provision? It's in the 2003 IRC, and the first printing of the 2006 IRC, but not the online 6th printing of the 2006.
"R311.2.2 Under stair protection.
Enclosed accessible space under stairs shall have walls, under stair surface and any soffits protected on the enclosed side with ½-inch (12.7 mm) gypsum board."
The photo shows the underside of new construction main stairs with the main water service shut-off. This space is "accessible", and I would assume HAS TO BE accessible because of the shut-off. The builder is saying it's not a storage area so doesn't have to be drywalled.
Similar Threads:Last edited by John Arnold; 11-07-2012 at 09:43 AM.
	11-07-2012, 09:42 AM #2
 Re: Under stair protection R311.2.2?
		Now I see it's in the 2009 IRC, under R302.7, so I guess that online 6th printing must just be defective.
	11-07-2012, 04:20 PM #3
		Nothing "happened to it" it is there in the edition and "printing" on-line you cite.
It is certanly "there" in the on-line free version of the sixth edition of the 2006 IRC (clickable link, scroll down) here: Chapter 3 - Building Planning
International Residential Code 2006 Edition (Sixth Printing) on-line FREE at http://publiccodes.cyberregs.com
The question IS, is the under-stair space "enclosed" (fully). Strictly from what has been photographed and described, that has not been established.
SECTION R311 MEANS OF EGRESS
R311.1 General.
Stairways, ramps, exterior egress balconies, hallways and doors shall comply with this section.
R311.2 Construction.
R311.2.1 Attachment. Required exterior egress balconies, exterior exit stairways and similar means of egress components shall be positively anchored to the primary structure to resist both vertical nd lateral forces. Such attachment shll not be accomplished by use of toenails or nils subject to withdrawl.
R311.2.2 Under stair protection. Enclosed accessible space under stairs shall have walls, understair surface and any soffits protected on the enclosed side with 1/2-inch (13 mm) gypsum board.R311.3 Hallways.
The minimum width of a hallway shall not be less than 3 feet (914 mm).
{end snippet}
The unsupported, sagging, unprotected or separated duct, and its relationship to the means of egress stairway brings up additional issues/concerns.
	11-07-2012, 04:30 PM #4
	11-07-2012, 04:40 PM #5
	11-13-2012, 07:26 PM #6
		I am not sure I am understanding the "enclosed accessible" part of this.
The below pictures are of a stairs in an as yet unfinished, but conditioned basement of a new house. Behind where I am standing to take these pictures are windows and a set of french doors leading to the back yard.
The lower run and landing are fully enclosed, but not accessible as there is no access door framed into the side walls. As I interpret the code this area would NOT need to have sheetrock installed.
The upper run are I believe fully enclosed, and accessible through the opening framed for a door into what is an under stairs closet. As I interpret the code this area would need to have sheetrock installed.
I have two questions.
1) Is my understanding/interpretation correct ?
2) Does the fact that these understair spaces are in a currently unfinished basement, although one intended to be finished, change how you would interpret/write up this particular example in your inspection report ?
Thanks in advance for the help.
PS. I hope this isn't too much of a hijack. I logged on to post this question and saw this thread at the top and figured it made more sense to join in an already existing discussion.
