Results 1 to 4 of 4
    Kerri McFarland's Avatar
    Kerri McFarland Guest
    Default kitchen cooktop island- elec outlet placement- Florida
    Can someone give me the code for electric outlet placement on a cooktop island...I am in Pinellas County Fl.
    Island is 76.5" long - 28.5" deep
    countertop behind cooktop is 6"
    there is 19.5" of countertop on each side of the cooktop.
    My understanding is that the cooktop divides the countertop creating 2 separate countertop spaces. Just not sure what that means regarding where the outlets should be placed.
    Thank you.
    Michel Cleark's Avatar
    Michel Cleark Guest
    Default Re: kitchen cooktop island- elec outlet placement- Florida
    Is this rule is applicable for whole US or some part of a USA? I am planning to buy a kitchen cooktop for my home.
    Quote Originally Posted by Michel Cleark View Post
    Many areas use this, but not all.
    Some building inspection departments use a different code
    Some have modifications to the code
    Check with your local building inspections department to see what code in in effect for your area.
    You say you are in Florida, the 2008 NEC applies here in Florida.
    That code section is just one of many which may apply to what you are planning on doing - you did not provide much information (only that you are planning on buying a cooktop).
