Results 1 to 12 of 12
    Apr 2008
    McKinney Texas
    Default No access to garage attic
    This detached garage did not have a means of attic access. Soliddrywall ceiling with no hatchway. I believe the 09 IRC specifes attic access, correct?
    Default Re: No access to garage attic
    I believe that the access is required only if mechanical are in the attic area.
    Apr 2008
    McKinney Texas
    Hi Scott, good morning and thank you for you input. That is what I thought also but the way I read the IRC it does not specify. It just says any attic greater than 30 sq feet. Also, there is wiring in the attic, (for lighting). Should not that wiring be accessible? (...maybe not...since wall wiring is not accessible either...).
    They'll be needing to fix that header over the doorway.
    I would say installing an access hatch is advisable and let them decide. It's a 20 minute job if you're slow.
    Nov 2011
    Oregon, USA
    And if you want it done right, make it at least an hour's worth of time by a reasonably skilled person.
    Did one a few years ago at a former GF's place, and it took me 2+ hours, including building a hinged/insulated hatch cover. Probably spent more than 20 minutes just going up and down the silly step ladder.
    But I never claimed to be reasonably skilled.
    Tolland, CT
    the wires dont have to be accessable but any junction box or connection of any kind has to have access to it.
    there should be ventalation to any enclosed non temperature controled space.
    Aug 2012
    Rock Hill S.C.
    Looks like there is a breezeway, could the garage be accessible that way?
    It wouldn't be easy or practical but it would possible.
    AND ...
    30" minimum headroom
    Does that have 30" headroom?
    Don't think the header is swayed ( unless the support walls are bow legged ) looks like camera angle.
    Apr 2008
    McKinney Texas
    Thanks for all for your comments. The photo was distorted (stretched) due to uploading to insepctionnews. The header is not swayed. There is no attic access through the breezeway, and yes, the headroom exceeds 30 inches.
    I think technically that access to this attic should have been provided, but it was not (by the tract home builder).
    Appreciate everyones input and have a Happy New Year.
    Gene
    Yep... 30sf of "floor area" and 30" headroom or no required access.
    Andrew Constantine
    InspectPro Home Inspections
    Charlotte NC Home Inspector
    MONTREAL QUEBEC-CANADA
    I concur.
    The image surrounds may make a chased lentil or header appear to have deflection.
    Good point.
