Results 1 to 19 of 19
Thread: notching
    so so, California
    Default notching
    This constitute notching in the center of the beam?
    Default Re: notching
    Is it a curved section above the fan mount that you are referring to?
    Was looking for sharp angles.
    Nope.
    Looks like a 3 piece box beam with the electrical supply inside the u shape. Structural support would be coming from the 2 side pieces.
    so so, California
    Pretty sure its one piece 4x. Its drilled from top to the bottom.
    It is not a notch. I am not a structural engineer.
    The lower face of the beam is in tension, and most of the fibers running past the fan are still intact, assuming the hole diam is about 3/4". Usual practice is to use a surface-mounted pancake style j box there and pull a single cable to it from the switch box. But we can't be sure what they did from this pic.
    Billy, your eyes are bad or very very good. That beam looks solid to me too.
    Yeah Thanks,
    Urban Dictionary: Eh hole
    so so, California
    Okay...you're right. Hole.
    They drilled from top to bottom then inserted NM through it.
    Ok. Was trying to look for a notch in the wood surface.
    The beam looks like a ridge beam. If so, ignoring the size of the rafters, a 1/2" hole through what looks like a 4x12+ beam would not have much effect on the presence use of the beam.
    Yeah Thanks,
    Takes one to know one, eh?
    Oh ya caught that EH ?
    Darrel Hood's Avatar
    Darrel Hood Guest
    If it is a ridge beam and, as it appears, the rafters are opposed, then for practical purposes the beam is carrying no load. In that case, the beam size is only a cosmetic choice.
    Lansdale, PA
    It looks like a rather low pitch roof. If there are no ceiling joists the ridge beam would be structural. Notching is much worse than drilling a hole. The strength of a beam is proportional to the square of the depth. Deflection is proportional to the 4th power. The strength and deflection are directly proportional to the width, so a reduction in width has much less effect. A 1/2 inch hole might reduce the strength of the beam by about 15 percent, but likely a bit less. I would get concerned if the hole was much larger than 1/2".
    Darrel Hood Guest
    Mark,
    Please, teach me. There is clearly a significant if not steep pitch. I'm guessing a 2 - 4
    pitch. I don't understand how opposed rafters with a significant pitch are incapable of supporting themselves without a ridge beam. Therefore, I need to learn what makes the beam structural. Also, I don't comprehend the relevance of ceiling joists to this conversation. That's something else I need to learn. Thanks.
    Jul 2010
    Summerville, South Carolina
    Mark,
    When there are no ceiling joists or collar ties the rafters will push the outside bearing walls outward. Therefore the ridge has to be designed as a beam to support the weight and prevent outward thrust.
    Aug 2011
    Hercules, CA
    Thumbs up Re: notching
    Quote Originally Posted by Ray Thornburg View Post
    Both of you explained it well, I agree!
    Thom Huggett, PE, SE, CBO
    Darrel Hood Guest
    I think I understand that you are assuming the beam to be supported by king posts on each end?
    Aug 2011
    Hercules, CA
    I hope it has posts at each end because the rafters sure aren't supporting it! Although we haven't seen all aspects of this member, I think it is clearly a ridge "beam" and not a ridge "board".
    Lansdale, PA
    A ridge beam must be supported by columns at the ends. BTW, to me king posts are part of a particular style of truss. I have never heard the term used otherwise.
    Regarding ridge beams, ceiling joists are only effective for lateral restraint of rafters down to about a 3/12 pitch. Below that pitch the lateral forces get so large that it is very difficult to make adequate connections.
    I wouldn't make a big deal about it. I've never seen a beam break from a 1" hole drilled in it. Just my 2 cents...
    Andrew Constantine
    InspectPro Home Inspections
    Charlotte NC Home Inspector
    Charlotte Home Inspections
