    Apr 2008
    McKinney Texas
    Default Seems a window type unit would have been a lot less expensive
    Installed in a enclosed patio. Seems a window type unit would have been a lot less expensive. I bet this set up cost over $3,000.
    (Idea: Spend $300 on installing window unit and use remaining $2,700 on flatscreen TV and hot tub).
    Cape Cod, Massachusetts
    Default Re: Seems a window type unit would have been a lot less expensive
    It would be difficult to install a window unit in those frames.
    Ken Amelin
    www.midcapehomeinspection.com
    Apr 2008
    McKinney Texas
    True, unless you modifiy the porch to hold a window AC. I bet I could configure or modifiy the porch to hold a window type AC for a lot less than the cost of this standup HVAC.
    Would have been a great place for a hotel room style split system along the bottom of the wall.
    I bet they knew somebody in order to buy the equipment and did the install themselves or their brother in law did it.
    Stupid, ugly, unfortunate.
    A ductless mini-split would have been ideal for that space.
    May have been installed by an a/c guy who had access to units he replaced and thought ... hmmmm ... I can use those instead of junking them ... ?
    Then the cost would be cheaper than a window shaker.
    Would hope that it was the left over scenario, had it why not use it.
    And/or possibly had the idea of also enclosing it at some time to make it look better.
    Apr 2008
    McKinney Texas
    I agree, either left-over equipment or someone got a really good deal on it, that is the only way it would make sense.
    Aug 2011
    Bigger and bet........well, bigger in Texas
    I just saw the identical set up in Saginaw.
    Maybe over done but without it that room would be 120 in the sun in the afternoon or more in the summer. A window unit would not have cut it.
    I just inspected another home that had an 8x12 enclosed patio. Glass all around. Winter as in now. That room was over 90 with the sun beating on it. I can only imagine how hot when it is 115 outside. Open the windows? Still hot as hell in the summer time.
