Thread: Heat Pump Identification
01-28-2013, 05:38 PM #1
Is a Model CKL36-1H Goodman condensing unit a heat pump? Could not see inside to see reversing valve.
I believe the second letter would be a P if it was a heat pump but I am not sure.
Similar Threads:Last edited by Frank Bombardiere; 01-28-2013 at 05:46 PM.
01-28-2013, 06:01 PM #2
Re: Heat Pump Identification
01-28-2013, 06:12 PM #3
01-28-2013, 06:25 PM #4
Here is a pic. I think it is not a heat pump.
01-29-2013, 05:05 AM #5
How about the thermostat inside the house? Was it a heat pump thermostat with an emergency backup heat mode option?
01-29-2013, 06:09 AM #6
01-29-2013, 06:42 AM #7
Reversing valve and accumulator pretty much means it is a heat pump!
http://www.jjeffzehnder.com/
02-10-2013, 06:12 PM #8
I train my inspectors, that no matter what the label "implies" ALWAYS verify the condenser is running when you have the thermostat in "heat" mode as sometimes things can change. Just because you are getting heat, doesn't mean the heat pump (if one) is running properly.
02-10-2013, 10:06 PM #9
02-11-2013, 08:22 AM #10
Here is a page I wrote to address this issue. Hope it helps someone. How do I know if I have a heat pump? | Blue Palmetto Home Inspection
