03-29-2013, 05:53 PM #1
safety glazing required next to tub in 1993?
Can someone verify for me that safety glazing was required in 1993 as it is now, when windows are right next to a bathtub?
Similar Threads:"There is no exception to the rule that every rule has an exception." -James Thurber, writer and cartoonist (1894-1961)
03-29-2013, 07:46 PM #2
Re: safety glazing required next to tub in 1993?
I do not know if it was required or not.
However you can (and should) still write it in the report as a safety concern.
03-29-2013, 08:10 PM #3
John,
Here are the relative pages from the 1991 UBC, which we were using in Montana at that time. 5406 D 5 etc.
03-30-2013, 03:25 AM #4
03-30-2013, 04:08 AM #5
03-30-2013, 05:29 AM #6
Pardon me John, I just realized the top portion of the page (797) did not copy. Sec. 5406-(d)-5 reads as follows: Glazing in doors and enclosures for hot tubs, whirlpools, saunas, steam rooms, bathtubs and showers. Glazing in any portion of a building wall enclosing these compartments where the bottom exposed edge of the glazing is less than 60 inches above a standing surface and drain inlet.
