Results 1 to 16 of 16
    Default spinning supply valves
    Not familiar with these supply shut-off valves. You can easily turn both of them, I mean the whole assembly, not the handles, yet they don't seem to be leaking. Could they be designed to do that?
    Default Re: spinning supply valves
    Looks like a Shark Bite.
    If so, then Yes, they will turn and not leak.
    Thanks, Rick!
    Yep, Shark bite or similar design 1/4 turn valve. Little freekish if you are not familiar with them.
    Rear (wall end) ring when compressed into valve will allow it to slide off the 1/3 " pipe. O-ring is the seal.
    I don't recall that Shark Bite fittings have nut flanges on them ... guess I should have looked on the internet (but I didn't).
    Jun 2012
    Texas
    Haven't run across them or at least didn't notice they turn.
    I did a new construction inspection the other day and saw some new white plastic shut off valves with round flat ends and you push them in to shut off the water and pull them out to turn it on. They seemed really cheap to me. Has anyone else seen these?
    Quote Originally Posted by Jim Starkey View Post
    Haven't seen anything like that here
    Might be a Texas thing
    Chandler, AZ
    Yes, the white ones I usually see with PEX piping. Although, I'm wondering why a home inspector would be operating/turning shut offs. Could be asking for trouble, we are not required to operate S/O's in AZ. You break it, you buy it.
    Dave Hill
    Buyers & Sellers Property Inspections LLC
    WWW.BuyersSellersPi.Com
    Quote Originally Posted by Dave Hill View Post
    Dang, if-n it's got a bertin (southern for button), lets press it and see whart (southern for what) happens
    Jun 2012
    Texas
    Well it was with PEX plumbing and I don't typically operate valves just to operate them but I had never seen them before and was just trying to figure out how they worked so if I client asks me I have a clue. It was brand new construction so I highly doubt they would break just by shutting them off then back on and if they did I wouldn't buy them, I would write them up as defective and in need of repair and go shut off the water to the house.
    Really? Grow up!
    Those cheap "push/pull" shut-offs are widely used here in FL, on new construction or re-plumbs. I operate them from time to time and can't ever manage to do it without the stub-out practically snapping off from all the force needed.
    Sorry Jim
    It was just an attempt at humor and in no way was it directed at you.
    I'm from Georgia and it was supposed to sound like southern drawl
    I have used it before on this forum.
    see http://www.inspectionnews.net/home_i...ndows-7-a.html
    Again, it was not directed at you.
    Oh,when I finally do see one, I will likely "Mash der burten"
    Sep 2007
    Fredericksburg, VA
    Yes, I've seen them. In one case it was a new house and most of the supply pipes were installed vertically though the floors. I pulled on one toilet shutoff valve and the CPVC supply pipe came up about 6 inches with the valve. Looks like someone forgot to install a keeper on the pipe.
    Stu, Fredericksburg VA
    May 2009
    Washington State
    Had 'em in our house (built in '99) They are cheap and I changed them out as soon as we moved in. If your pipes are stable in the wall, they won't be after a few uses of these valves. They also really make the pipes "hammer" due to being "full on - full off" all at once - Steel braided lines and quarter-turn ball valves is "the only" way to go - sinks, toilets, washing machine, water heater - you name it.....JMO
    Apr 2011
    Centennial, CO
    The white push on are called Accor (like Accord, without the d).
    We sell around 30 kits a month. Definitely a price point item, but we don't have any problems with them when they're installed correctly.
    Steve
