Results 1 to 16 of 16
    WilliamGreen's Avatar
    WilliamGreen Guest
    Default What do you call this plastic type of water pipe.
    Came across this clear plastic pipe in a home. Is it a form of pex. the connecters are plastic fittings. What do you call this type of plumbing.
    Aug 2011
    Default Re: What do you call this plastic type of water pipe.
    WIRSBO is the brand that I've used. Pronounced wersbo. Great stuff. It requires a special tool for the connections.
    WilliamGreen Guest
    Thanks that helps a lot.
    Uponor now.
    Sep 2009
    Arizona
    The brand I see most often in the Phoenix area is "aqua pex".
    Oct 2008
    Portland, OR
    SharkBite make a lot of pex now. The fitting is a ProPEX Expansion fitting. Good stuff.
    Last I hate seeing that unsupported bend after the fitting. Especially with how stiff 3/4" pex is..
    Utah
    Quote Originally Posted by WilliamGreen View Post
    Sorry to jump off topic, but what is that yellow thing to the left?
    Sep 2007
    North Las Vegas Nv 89081
    Looks like polybutlepropoline. Not sure if I spelled it right. WE have a lot of that here.
    Alain Charron's Avatar
    Alain Charron Guest
    I personally think it is safe to just mention it as being "PEX" as opposed to "AQUA-PEX" or "WIRSBO-PEX"... As long as it is NOT POLYBUTYLENE.
    Oct 2011
    california
    Quote Originally Posted by Jerry DiGiovanni View Post
    What are you guys talking about this pipe is PEX the other comments are the fastening systems and brand names It should be supported every 32 inches on horizontal joist runs extremely durable if not a rodent issue or exposed to sunlight
    Marshall Brown's Avatar
    Marshall Brown Guest
    Could someone clue me in as to what PEX is the abbreviation for. I was told once that it was the abbreviation for the French name for cross stranded polyethylene, but I have been told a lot of things, not all of which were true.
    Quote Originally Posted by Marshall Brown View Post
    PE is polyethylene, and the X is for crosslinked.
    From Uponor site:
    "Wirsbo emerged as the leader in the polyethylene pipe industry in 1968 when German inventor, Dr. Thomas Engel, developed a method to chemically crosslink polyethylene (PEX). A year later, Wirsbo successfully developed a viable manufacturing process, and in 1984, Wirsbo was incorporated. "
    From Uponor site:
    As the Uponor representative explained it so we (at the meeting) could get a visual image of it): Those Solo plastic cups are made of polyethylene with no cross-linking, you know how you would take those cups and bend the top, cracking it, then rip it straight down the side of the cup? That what would happen to the piping if it were not cross-linked. That was solved by adding in thousands of tiny men who clasp arms together very tightly and keep the polyethylene from tearing like those cups ... ... actually, if I remember correctly, it was the addition of hydrogen-peroxide to the polyethylene which causes the molecules to grab each other and hold tight.
    Jun 2011
    Mississippi
    As the Uponor representative explained it so we (at the meeting) could get a visual image of it): Those Solo plastic cups are made of polyethylene with no cross-linking, you know how you would take those cups and bend the top, cracking it, then rip it straight down the side of the cup? That what would happen to the piping if it were not cross-linked. That was solved by adding in thousands of tiny men who clasp arms together very tightly and keep the polyethylene from tearing like those cups ... ... actually, if I remember correctly, it was the addition of hydrogen-peroxide to the polyethylene which causes the molecules to grab each other anWow! That's a great visualization Jerry. Do you know of any documentation on that thesis that I might aquire for some light bedtime reading?d hold tight.
    George Hallaron: Owner primary inspector
    Bienvenue Home Inspections LLC
    www.bienvenuehomeinspections.com
    Quote Originally Posted by George Hallaron View Post
    I didn't get the names of all those men, probably small relatives of either the Munchkins or the Kebbler Elves.
Tags for this Thread
