Results 1 to 17 of 17
    so so, California
    Default Check out this drop
    Crazyness.. CA style
    Default Re: Check out this drop
    If the earth under your feet out there didn't shake the houses so much ... that mast might still be straight and not bent.
    Oh, wait ... you were showing us those little ol' wires over the pool ... just don't use them as a clothesline and use metal hangers to hang wet swim suits from it.
    Jul 2010
    Kansas City Missouri
    It could be used as a zip line to drop into the pool from.
    Galen L. Beasley
    Inspections Supervisor
    Housing Authority of Kansas City MO
    so so, California
    Quote Originally Posted by Galen L. Beasley View Post
    Yea, I think is was...
    Mbrooke's Avatar
    Mbrooke Guest
    I vote pool company special
    Aug 2011
    You guys are so critical!
    Tabb Jensen's Avatar
    Tabb Jensen Guest
    Not enough pics - -- possible - tree limb on wires bent original mast - ( this happened at my house - bent mast clear to roof ) (run was also to long(weight)) - ( I replaced mast and added a new telephone pole close to house) - They used bent mast for wire support and made new mast. Clearance appears to be an issue. Handyman Tabb
    Feb 2010
    Wenatchee Wa
    I like the zip line idea. Can charge extra for the fun
    Don Hester
    NCW Home Inspections, LLC
    Oct 2009
    michigan
    You foo's, anyone knows there's only so much slack in themthere drops!-
    Tis why the custom bend. Anyone knows that the pool mustof been there first, sheesh.
    Jul 2009
    CT
    Marc, your pic left out the most important clue. The diving board. It must be just out of camera range, or was removed- it's obvious someone was using the service line for some sort of acrobatics after getting a good launch from spring board. Perfectly safe, as long as you don't touch anything else while twirling around those wires.
    Curt
    Quote Originally Posted by Curt Downs View Post
    Let me understand this - your hands are grasped around 3 conductors and two of those conductors are 120 volts from the third conductor, and your hands are nice and wet as you grasp that line and twirl around it (supposing the outrageousness of this were to actually happen ) - I'm not following the "Perfectly safe" part. I understand that you are referring to one not being 'on ground', but that bare neutral grounded/grounding conductor serves the grounding purpose as being 'on ground'.
    Oh, yeah ...
    Jul 2009
    CT
    Oh, yeah ...
    Darn Jerry, I guess I better add, 'don't try this at home- or anywhere else.' I was shocked by your answer (not as shocked as if I had tried it). Anyway, that mast will be flat on the roof soon, so it shouldn't get too much lower. You may have to limbo under it to get to the pool.
    Curt
    Oct 2009
    michigan
    Laughingly I remember a tough carpenter grabbing a drop that I was tying up to a new mast to help me. He was laughing because I had my insulated gloves on.
    Not only did he let go in the biggest of hurry, he kept shaking and throwing his hand about as though he had the booger from hell stuck to it. It left a perfect X-ray picture of a triplex on his hand! AH, the memories
    I think Curt meant "perfectly safe for Curt"
    If it were a movie I would have liked to see what happened when the live wires hit the pool with a half dozen people in it. Shake, rattle and POP!
    If it were a movie I would have liked to see what happened when the live wires hit the pool with a half dozen people in it Shake, rattle and POP! NOt sure if I ever saw that in a movie or not. I guess I would have remembered.
    Jul 2009
    CT
    Angry Re: Check out this drop
    It's called thinning of the herd. Hey, wait a minute......... Thanks to Jerry, I canceled my 'twirling trip.'
    Aug 2011
    I wonder what is actually "perfectly safe"?
