Results 1 to 12 of 12
Thread: Age of Climate Master Geothermal
03-05-2013, 04:45 PM #1
I finally found one I can't solve! This doesn't add up....
House built 2000
But HWH is 2004
Climate Master Heat Pump
S# B10483591
Coils rusty. Looks more like 8-13 years
Digest says 1st letter is month, second two are year. No way this is 2010.
Any similar experience? Suggestions?
Thanks,,
Andy
03-05-2013, 05:27 PM #2
Re: Age of Climate Master Geothermal
I have a Climatemaster Geo Thermal Heat Pump
My unit serial no. is: L13781102. It was installed Oct 2008.
Your unit S# B10483591
I think you have a unit manufactured sometime in 2004 or 2003?
manufacture or age of an CLIMATE MASTER® furnace or other CLIMATE MASTER® HVAC units | Building Intelligence Center
Was there a former heating unit that was replaced in 2004 with this unit?
03-05-2013, 05:30 PM #3
No. Geothermal installed in new construction.
I think the guy was doing bits and pieces as he got the money.
I'm wondering if he didn't start permit in 2000 and finish in 2004!
AM
03-08-2013, 08:10 AM #4
The link attached is incorrect for a serial number of this type. Starting in 1999, ClimateMaster uses the first letter to refer to the year: B = 2000. The next number is almost always 1 (probably an internal reference for CM), then the next two numbers refer to the week. Not all letters are used, hence L refers to 2008.
B10483591 was built in the fourth week of 2000.
03-08-2013, 01:25 PM #5
Thanks David.
11-21-2013, 07:29 PM #6
11-21-2013, 07:57 PM #7
Go here: Building Intelligence Center | Your #1 resource for determing the date of manufacture or age of HVAC & Water Heater equipment.
Click on HVAC Production Date/Age in left column
Click on Climate Master in the list (you should be here: manufacture or age of an CLIMATE MASTER® furnace or other CLIMATE MASTER® HVAC units | Building Intelligence Center )
The examples don't quite match the dates of construction or the water heater date ... unless ... unless we do what Dave said and ignore the first '1' digit after the number, then it matches the water heater date as the date would be: B10483591 or February of 2004.
If you ignored the first '1' in the example on that website, the date of manufacturer would not be affected because K111 would still be October of 2011.
Just sayin' ... it works out if that is done.
11-22-2013, 05:36 PM #8
11-22-2013, 05:50 PM #9
I suspect that Raymond's unit follows the Style 3 serial example - not sure what letters between E and N represent which year, but his L number fits between the two example letters shown (E=2003 and N=2010, Raymond's L=2007/2008 so it fits between the two shown).
11-22-2013, 06:33 PM #10
11-22-2013, 09:05 PM #11
Many skip I and J because those two can be confused, Q is also skipped because it looks like O, and some skip O (as in M-N-O-P) because it can be confused with 0 (as in 0-1-2-3).
If they skipped I, J, and Q, then the list would be:
A=1999
B=2000
C=2001
D=2002
E=2003 (which is shown in Style 3)
F=2004
G=2005
H=2006
I=(usually skipped)
J=(usually skipped)
K=2007
L=2008 (Raymond's)
M=2009
N=2010 (which is shown in Style 3)
O=(frequently skipped)
P=2011? (2012 if O is not skipped)
Q=(usually skipped)
R=2012?
S=2013?
Just guessing ...
12-18-2014, 03:28 PM #12
