Results 1 to 4 of 4
    Apr 2010
    Default How Do You Describe This?
    When it came time to write this up I wasn't quite sure where to start.
    Atlanta, Georgia
    Default Re: How Do You Describe This?
    Non standard unconventional waste plumbing observed. Improper joints and mixed materials. Recommend replacement by a competent plumbing contractor.
    Quote Originally Posted by William Kievit View Post
    ... I wasn't quite sure where to start.
    Start with: This is wrong in so many ways that the easiest to understand way is this - Have plumbing contractor remove this mess if no longer being used, or correct this mess if it is in current use.
    Looks like a Rube Goldberg design!
Tags for this Thread
