04-06-2014, 10:52 PM #1
04-07-2014, 03:51 AM #2
Re: Central Vacuum Plumbing & Attic Heat
04-07-2014, 07:02 AM #3
Did they use pipe for central vacuum systems of regular PVC thin wall pipe?
I think pipe for central vacuum systems is PVC of a different formulation and is stiffer, probably less susceptible to heat and collapsing like that.
That is pretty wild, though.
04-07-2014, 07:40 AM #4
The gable roof had only 2 metal dormer type vents (one in the middle of each slope) with no lower vents, no ridge vents, no gable vents and a black composition dimensional shingle. At 11:00am and 75 degrees outside, the attic was already very warm and really muggy...that place must be sauna in the summer. Further, it looks like the wrong PVC. This site makes that point: Central Vacuum PVC and Plumbing PVC
04-14-2014, 01:29 PM #5
04-15-2014, 05:38 AM #6
"One thing about your central vac. You can't run it on a sunny day. Only at night. That's all, have a good day."
It must have been like sucking on a straw in a thick milk shake.
"George! The vacuum was sucking great for a minute but now it won't pick up anything!"
04-25-2014, 09:33 AM #7
Probably wrong type of pipe and then it collapsed while running due to being soft from the heat. Or that vac had one hell of a motor on it.
