    Default Can't make this stuff up
    Nowhere to mount this sprayer on the replacement sink, so we'll just let it hang out in the cabinet.
    Is it still connected to the water supply, you ask? Of course it is!
    Nampa, Idaho
    Default Re: Can't make this stuff up
    I have seen that more than once.
    Yep, seen it before. There is actually a small brass cap available to block off the hose connection.
    877-466-8504
    Pat Young's Avatar
    Pat Young Guest
    Just set-up as a vermin shower. You don't want dirty rats in your house.
    I always worry about people pushing stuff under the sink when I see things like that. If you push the right thing under the sink, and everything lined up just right, it would be quite a surprise....
