    Default kitchen sink supports?
    This is a relatively high-end house, otherwise I'd just write these things off as home-owner nonsense.
    Default Re: kitchen sink supports?
    Those were quite possibly intended as temporary support only - they likely were there to hold the sink up while the silicone/adhesive/sealant (used to bond and seal the undermount sink to the underside of the granite) set up and cured.
    They quite possibly forgot to comeback and removed the temporary supports.
    Of course, though, temporary supports are usually not attached to the sides of the cabinet, they are usually from the bottom of the cabinet up to the underside of the sink and leave no nail/screw holes behind when removed.
    Virtually every under-mount sink that I see has this.
    And this, too?
    But they are temporary and can be removed, right?
    John,
    Yep, those too.
    I would guess temporary. For an SS sink you shouldn't need those. However, homeowner could have had issues in the past with the caulk seam failing or maybe they own lots of AllClad.
    It looks like the screws on the sink clips are not run up tight or are the wrong screws for this type of counter top material. Looks like this was a temp measure and never removed or a "hack" to save the trip back to get the right screws.
    These little "details" are frequently skipped / missed. I think it is why it is very common to see j-box covers missing or never closed, way back in the attic or under the house.
    "C of O is signed off - we're outa here!"
    877-466-8504
    Aug 2011
    I don't see a "defect" with the braces.
    I see that often with undermount sinks, and I see nothing wrong with it. A little extra support never hurts with an undermount sink like that.
