Thread: Weep holes over lintels
11-15-2007, 12:23 PM #1
Similar Threads:Last edited by Scott Lynch; 12-20-2007 at 04:43 PM.
11-15-2007, 05:21 PM #2
Re: Weep holes over lintels
Scott, the Brick Industry Association shows details about weeps and lintels.
See link below:
http://www.bia.org/bia/technotes/TN7.pdf
11-16-2007, 04:20 PM #3
The short answer is - yes. Flashing and weeps are required over lintels, although it is VERY often not enforced.
As to the arch, I would not make an issue out of that. It is directly under a soffit so where is the water going to come from? Further, I'm not sure weeps would even function there at all anyway. IMHO it is a non issue.
12-02-2007, 08:22 PM #4
12-03-2007, 06:51 PM #5
So WE should 'choose' what our client's get to know ???
If you know something is a defect, report it....inform them. But also inform them of the implications so they can be advised as to the significance and decide what THEY want to do (consult with a mason?).
I tell clients when weep holes are absence and, in so many words, I also tell them of the complications of trying to do something about it after the fact (do we know if the drainage plane is actually there, will the guy with the drill puncture the drainage plane if it is there, etc.).
