Results 1 to 17 of 17
Thread: what is this?
07-23-2014, 03:02 PM #1
what is this?
Hello,
I was hoping someone can tell me what this device is? Observed on a new construction, pre-walk through inspection.
Thanks!
07-23-2014, 03:59 PM #2
Re: what is this?
Looks like an accent light, but it looks like it is pointing in the wrong direction.
07-23-2014, 04:11 PM #3
Re: what is this?
I didn't see a bulb. I *think* it's some type of sensor, or an alarm. I hate it that I don't know what it is! LOL!
Just hoping someone has seen one.
Thanks.
07-23-2014, 04:18 PM #4
Re: what is this?
I have no idea what it is.
Just a wild guess: rain gauge.
07-23-2014, 05:42 PM #5
Re: what is this?
That's what it looks like.
Rain gage sensors are required in many places when an automatic (timer controlled) lawn irrigation system is installed.
Some places install moisture sensors in the ground instead.
Both serve the same purpose - bypasses the timer controller so the system does not operate.
If a place has ever had a drought, faced the liklihood of a drought, or plan ahead for water restrictions, etc - those are some of the first things required as a means to conserve water.
07-23-2014, 06:32 PM #6
07-23-2014, 07:12 PM #7
Re: what is this?
07-23-2014, 08:28 PM #8
Re: what is this?
Mazza Inspections and stuff...
https://mazzainspections.com
https://waterintrusionspecialist.com
07-23-2014, 10:06 PM #9
Re: what is this?
How does it measure when it is full? How do you empty it? And it can't be accurate unless it is straight.
I have seen rain gauges but never one like that. The clear plastic type is easy to read but needs to be emptied regularly.
There is a neat design that is a spoon on a pin with a weight. Every time it tips it dumps the water and a counter records it. That one needs no maintenance.
07-23-2014, 10:20 PM #10
Re: what is this?
07-24-2014, 04:44 AM #11
Re: what is this?
There are several other styles which are similar to the one shown, none require maintenance.
Yours with the mechanical lever and spoon can bind up and not tip, not collect enough rain to tip and then evaporate - they are all about the same in accuracy ... they aren't.
The contain a material, as do the one which are installed in the ground, which get wet and that wetness (moisture) is detectable (think moisture meter), at some preset level they permit/do not permit the pump to operate.
07-24-2014, 04:52 AM #12
Re: what is this?
Weather station for WiFi irrigation controller
Bruce Thompson, Lic. #9199
www.TylerHomeInspector.com
07-24-2014, 08:55 AM #13
Re: what is this?
Thanks All!
I googled rain and weather stations, it does look similar. Although I couldn't find an exact match.
I did read that some of the rain gauges calculate by weight - so even if there is water in there, it can still measure new rain fall by seeing how much more weight has been added. Of course that is just my explanation, I could be way off base.
Thanks again!
07-26-2014, 05:16 AM #14
Re: what is this?
Regardless of what it is, it's mounted on the banding of the cladding. Make sure all penetrations are properly sealed or you may have moisture intrusion problems
07-28-2014, 06:47 AM #15
Re: what is this?
It's a Rain Bird Smart Controller. Fairly new.
http://www.rainbird.com/documents/turf/bro_ESP-SMTe.pdf
Dom.
(Don't know if the link will work...)
07-28-2014, 05:02 PM #16
08-01-2014, 09:26 AM #17
Re: what is this?
As an aside, back in college (way back in college) my roommate ran a sprinkler business on the side.
He said one of his biggest money makers were the rain gauges. According to him, they were a little tricky to put back together, but once you knew how, would only take a few seconds.
He would install them, and people would allways wonder how they worked, and take the cover off to look at them. When they could not get them back together, they would have to call him for a service call.
-dave
if it rains the automatic irrigation system is permitted to operate, otherwise it is not.
