Results 1 to 12 of 12
    Feb 2010
    Irvine, California
    Default water heater vent clearence
    This 150+ unit condominium is built in 2010. equipped tankless gas water heater in the garage and vent is terminate right under the living room window ( less than 4ft)
    if I write it up, what option the owner has ?
    In this home, next door's vent is there too.
    Atlanta, Georgia
    Default Re: water heater vent clearence
    Quote Originally Posted by Ben Im View Post
    The owner can have it fixed. Just extend the pipe vertically above the window. Ugly but effective.
    Feb 2010
    Irvine, California
    I'm sure, the HOA will not let the owner to do it.
    Did you look up the specs for the vent clearances to a window from Rinnai? They are sometimes much closer than you think they should be. Is that where you got the 48" from?
    Feb 2010
    Irvine, California
    No, it's not.
    The 4 ft is from just common rule.
    Maybe the tankless WH is different..
    Anyone knows?
    Search for that model Rinnai manual and look it up in the installation instructions. I think it is 36" in Canada, but 12" is good enough for you'all.
    http://www.rinnai.us/documentation/d...7-077x0101.pdf
    Page 26. It is 12" in the USA.
    Feb 2010
    Irvine, California
    Thanks,
    Only 12" ...
    Rinnai tankless WH equipped with CO filter or something? Hum,,
    Not that anyone is reading the installation instructions you posted or anything ... ... but I think you meant page 29.
    Or could it just be my small Samsung Galaxy Note 2 phone screen (as has been suggested in another post).
    No, it's not.
    Anyone knows?
    Dude, that's kind of your job here. If there is a question, you need to look up the model number and verify before reporting as long as the information is available.
    thanks, JP. He can read Page 29 and the preamble starting at around page 26.
    so so, California
    Dont forget slope of vent...check for passive condensate drain if required..
    Oct 2011
    california
    refer to manufacturer which likely requires minimum of 4 ft to operated window remember one is intake and one is exhaust that likely can be added to to force adequate clearance Also expect for Navien gas line must be 3/4 and gas line should have a sediment trap
