Results 1 to 11 of 11
08-21-2014, 07:56 AM #1
Unknown piping in new construction
Took a walk around a newly house and saw this pipe with a yellow polypropylene line and another rope sticking out.
This was near the lateral electrical service entrance to the home which is to the right of itphp0AzUs4AM.jpg.
What is this?
08-21-2014, 08:27 AM #2
Re: Unknown piping in new construction
It's a spare conduit for someone. In our neighborhood is was installed for phone and CATV, neither of which have ever put their service underground. The rope is to be used either to pull the wire, or to pull the larger rope in which will then be used to pull the wire.
08-21-2014, 08:42 AM #3
08-25-2014, 05:51 AM #4
New kind of underground feeder cable. It's polypropylene to resist polyestermites!
08-25-2014, 08:26 AM #5
I concur that this is a run for future use. I custom homes I have seen a lot of this with up to 3 inch conduits. Runs for future landscape low/high voltage, runs for future outbuilding power and even for main runs of sprinkler lines and control wires (especially common under concrete driveways, patios etc). If there is nothing in it, there is usually no code regarding your inspection. Since you don't know the use and the trench is filled it is hard to say whether the future use will be to depth of code etc.
On can note the existence and state that if it was not on a permit and inspected it may not meet any specific code for a given future use.
Here in FLorida, the fiber optic companies REFUSE to install at required depths. They install only a couple inches deep and forget it (easy to dig sand and they still wond do it right). I had to make a run just like that for my fiber optic (I went 16" deep in conduit) as it kept popping up and being mowed. Always thier fault and extremely expensive for them to repair!
10-16-2014, 11:46 AM #6
10-16-2014, 02:11 PM #7
If there was some way to prove it and bring it to the attention of each state's public utilities commissions then we could do two things
1. Have them MEET CODE
2. Reduce all future income by the expected value of the labor and material for repair of non-compliant installations, make them pay fom thier own money, not ours.
10-17-2014, 08:26 AM #8
Interesting. Tough thing is, it is tough to prove a negative. I suppose the right thing to do would be to call them out on it each and every time and make them comply. Unfortunately, though, most people don't know any better. I've never looked, though, is this issue even covered in the NEC?
10-17-2014, 09:01 AM #9
12-03-2014, 01:37 PM #10
12-03-2014, 09:14 PM #11
You are correct that this is a question. In Dallas the city imspector required 18 inches for My job's communications install. Ths happens to mirror the Tabe 830.47 requirements for Network-Powered Broad Band Communications Systems Minimum Cover. The question is does fiber optic meet the definition of that code?
In another post somewhere in the past someone stated that regardless of depth, it must be placed deep enough and in a manner that will not allow damage to the cable from normal activity, That would be cars driving over it, rototillers, shovels and other activity. Fiber optic is supposed to be a "permanent" installation.
