Results 1 to 3 of 3
Thread: SE needed?
11-19-2007, 05:02 PM #1
SE needed?
11-19-2007, 07:18 PM #2
Re: SE needed?
What is supporting those steel posts? Are there footings under the slab below each post or are the loads carried only by the concrete slab? (It looks like a former concrete patio to me.)
Did you probe the steel posts to see if the rust has damaged the structural integrity of the posts?
Bruce Breedlove
www.avaloninspection.com
11-20-2007, 09:40 AM #3
Re: SE needed?
Look at the lower right photo which shows the Front Right Post with the tree in the background - see how much that bows out?
I think the first order of business would be to have a contractor open things up ... *then* call in the SE.
I'm guessing that the Left Rear Post goes down to a footing through the porch slab, it also looks to have been repaired once before. The rusting is breaking the concrete out around the post.
I suspect that bulge at the top of the Front Right Post is from rust - and that much rust is not a good thing.
