Results 1 to 14 of 14
Thread: Light Switch
    Aug 2009
    New Jersey
    Default Light Switch
    Has anybody seen a switch like this? what is the function of the button?
    Aug 2011
    Default re: Light Switch
    Haven't seen that. But is that a true button or a led light?
    Aug 2009
    New Jersey
    It is a clear button.
    Is it a button or an indicator (light bulb or LED or similar?)
    Likely a toggle switch with a built-in indicator.
    Dom.
    Aug 2009
    New Jersey
    Dom.
    It is an actual button
    Martin, you were there, did you push the button to see what it did? What did the switch control?
    Spring loaded lock switch, to lock on or off?
    David Caldwell's Avatar
    David Caldwell Guest
    Default Re: Light Switch
    Rheostat switch perhaps?
    May 2008
    N. Syracuse, NY
    Lightbulb Re: Light Switch
    Quote Originally Posted by David Caldwell View Post
    I was thinking world's smallest rotary dimmer.
    Looks like an old switch with an indicator light.
    Aug 2011
    Yeah, my question exactly. Interesting that none of us have seen that.
    Mar 2014
    Ozark, Missouri
    Probably a glow in the dark glue-on button that was sold on TV. The nature of the switch design makes it almost impossible to install any wires or linkage within the toggle itself.
    Modern lighted toggles have a plastic toggle that transmits light easily from inside the switch, so it would be unnecessary to add a light transmitting rod, unless it was a crude prototype.
    Nov 2014
    NY
    Quote Originally Posted by Martin Muth View Post
    Hardwired Clapper
    Did the bedrooms have shag rugs?
