Results 1 to 16 of 16
Thread: water heater veny pipe slope
01-13-2015, 12:45 PM #1
01-13-2015, 01:34 PM #2
Re: water heater veny pipe slope
Yes, looks fine to me.
01-14-2015, 07:07 AM #3
01-14-2015, 07:21 AM #4
01-14-2015, 07:47 AM #5
Sorry Raymond, I cast my lot with Jerry. Technically not correct but in practical application here will not cause a problem. Which may be what you want to note. If for no other reason than to demonstrate that you looked at it.
That must be a real short furnace, or is just an illusion.
01-14-2015, 08:20 AM #6
Those runs don't look long enough to need strapping.
Without speaking for Raymond, my comment was meant to more in line with Jerry's. The negative run here is too short to cause a problem.
Funny you mention a short furnace because I thought the same thing.
01-14-2015, 08:43 AM #7
01-14-2015, 09:39 AM #8
I don't think its worth writing up as deficient. At first I thought the angle was the result of the angle of the photo, but upon second look I see the small horizontal run is off by maybe a 1/4".
01-14-2015, 06:10 PM #9
I think it would go in my report as an observation. 'If the WH produces a lot of condensation it might cause corrosion of the furnace vent'.
Then it will depend on the lifestyle of the occupants, and probably they will do nothing about it.
I wonder of the paint is concealing rust?
01-14-2015, 06:55 PM #10
01-14-2015, 08:20 PM #11
In my view condensation likely would not be a problem. The flue runs up through the house, so it's always warm, plus a naturally aspirated furnace with standing pilot coming up below the HW tee will help in keeping the flue warm. Paint is not going to hide corrosion in my opinion.
01-15-2015, 04:32 AM #12
Raymond,
I stood on my chair trying to see down to the wee little furnace, but couldn't see if. Do I need to get higher above the screen to see it????? Or is it your Latitude above CO that gives the better perspective???
01-15-2015, 10:03 PM #13
A negative slope is never allowed, no matter how short of distance. Write it up, or when the brother-in-law plumber comes to visit and says "your home inspector should have caught that" you'll be paying to have it corrected.
01-16-2015, 03:44 PM #14
What do you suppose the odds are, that the original installation did not include an improper slope. But the lack of support is the result?
01-16-2015, 03:55 PM #15
or... what came first the furnace installation or the water heater? Perhaps the slope was correct until the furnace got installed and vice versa.
01-19-2015, 08:14 AM #16
I've never seen a shut-of valve in a PEX loop before. I agree with Jerry... strap it.
