Results 1 to 12 of 12
02-28-2015, 09:48 AM #1
cement block with unknown drain of filler neck
I was at a a house from 1941. in the back yard was a large cement block with either a filler neck or drain. Does anybody have any ideas what this might be?
02-28-2015, 01:49 PM #2
Re: cement block with unknown drain of filler neck
It looks like a concrete laundry tub turned upside down and that pipe is the drain.
02-28-2015, 02:33 PM #3
I concur with Raymond, at first it looked like a possible underground storage tank, but it really does look like some sort of basin turned upside down.
02-28-2015, 03:13 PM #4
02-28-2015, 03:33 PM #5
My second guess would be the top of a former cistern or septic/grey water tank.
02-28-2015, 04:50 PM #6
02-28-2015, 07:18 PM #7
02-28-2015, 07:22 PM #8
Correction: It is a 'concrete' object, and one of its ingredients is 'cement'.
It is a bomb shelter for rodents. Doesn't everybody have them?
03-04-2015, 07:04 PM #9
I agree, it's just an upside down concrete laundry sink sitting on the ground.
03-05-2015, 07:14 AM #10
Base for the dog's hot tub.......
It sure looks like an upside down basin. Is it stuck/frozen to the ground?
03-05-2015, 05:55 PM #11
Raymond nailed this one. The drain assembly looks like thousands that I have seen. So does the shape. They usually sit on steel or cast iron legs.
03-05-2015, 06:09 PM #12
Mark you are repeating yourself.
Yes do a Google search using term "concrete laundry tub" and then go to images, different stands, et ceteras.
