Results 1 to 2 of 2
    Brian Cooper's Avatar
    Brian Cooper Guest
    Default Water Purity Test
    Can anyone provide assistance on offering a water purity test to my clients? What services do you provide? What are your normal fees? What does your report look like? Thanks...
    Default Re: Water Purity Test
    Quote Originally Posted by Brian Cooper View Post
    Unless you are in an area that has a large number of homes on private wells I would not worry with it. Even with well systems, most must be certified by local health departments before a home can change ownership.
    I have done some water test but I always used a local lab. I tell them what I wanted to test for, they would prepare the containers and give it to me in a small ice chest. Most test require you to maintain the temperature of the sample, but it depends on what is being tested.
    I would then return the sample and the chest to the lab. They would process and provide the results to me and then I would forward to my client. I marked up the test by 30% to cover my time.
    You must follow protocols, most are set by the lab you work with.
